Recessed Outlet Box / Faucet For Ice Maker - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-21-2009, 06:53 PM   #1
Recessed outlet box / faucet for ice maker
Has anyone ever seen a recessed water outlet box similar to a washing machine made for an ice maker?
I just bought a new fridge for my new house (fridge sits by the range and cannot use the sink supply since it's on the other side of the kitchen) and absolutely HATE the cheap-A**ed crap they sell to hookup an ice maker (Said junk of which was installed by previous owner of my house....of course)
The hookup that came with the fridge is of high quality....but the JUNK they sell to tap into a water line with should be outlawed IMO.....
Thank ahead of time for anyone with ideas.....
Randall53 is offline   Reply With Quote
Old 11-21-2009, 07:11 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Home Depot has them.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 11-23-2009, 06:48 AM   #3
Junk
After you buy the box setup buy a small roll of copper and individual parts to tie the ice maker in to the water line (if you can solder) cut the cold water line install tee and regular valve with reducing fittings to 1/4 " copper. Then you eliminate the cheap saddle valve and plastic tubing.
When you install the copper make sure you leave all the roll attached so when you pull the refrigerator out for cleaning the copper roll will open like a slinky and will push back together when you put the refrigerator back.
PS: Don't forget to shut the water off first.
SULTINI is offline   Reply With Quote
Wiring a GFCI Outdoor Outlet from an Inside Outlet - Parallel or Series? Pacal Electrical 28 11-13-2010 03:36 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 09:33 AM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 09:05 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 03:59 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 08:45 AM
