Recessed 1.5" Nipple Removal? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-24-2010, 10:10 PM   #1
Rewards Points: 79
I'm replacing my bathtub and the drain line has a 50-year-old 1.5" galvanized nipple coming out of cast-iron that I need to remove. Problem is, the nipple is in a pit and completely below the level of the foundation (I'm on a slab) and I can't grab it with a pipe wrench.
Any suggestions on how to get ahold of that pipe so I can twist it out?
thebigsee is offline   Reply With Quote
Old 01-24-2010, 10:35 PM   #2
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
that sucks! can you make the hole bigger?
plummen is offline   Reply With Quote
Old 01-24-2010, 10:48 PM   #3
Rewards Points: 79
I could, but really would like to avoid that! It's about 16" in diameter now, not enough to get a long enough wrench in to get some leverage.
Old 01-24-2010, 10:57 PM   #4
plummen's Avatar
how long is pipe nipple? can you collapse the end of nipple enough to pry it out without hurting the fitting its threaded into?
Old 01-25-2010, 12:19 AM   #5
Rewards Points: 79
It's about 6" long. I don't feel good about collapsing it, it would be a big headache if the cast iron threads were damaged.
I think I'll probably have to drill a hole through it or cut a groove at the top and insert something like an emergency shut-off bar to twist it from above. I have dosed it a few times with P'Blaster and that will make a big difference. It's just getting a good grip on it and having some leverage is the problem.
Old 01-25-2010, 06:22 AM   #6
plummen's Avatar
if you can hit it with a big chisel where it threads in sometimes you can squeeze it in on itself to where it can be wiggled out depending on how rusty it is
Old 01-25-2010, 06:34 AM   #7
I'd start dumping penetrating oil down around the threads every couple hours and tapping in it while Yeah I Know Digging to get at it. Whew!!
Hopefully when you are able to get at it it will give from the oil.
Good Luck
SULTINI is offline   Reply With Quote
Old 01-25-2010, 07:46 AM   #8
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,074
Ayuh,.... You need a wrench like This,....
If you have Oxy/ Ac torches,... Heat the pipe nipple Red hot,+ quench it with cold water,...
It'll break free,+ spin out quite easily....
Penetrating oil don't do much good, it can't penetrate any better than the water that's been in the pipe for the last 50 years...
Old 01-25-2010, 08:21 AM   #9
The oil will work if it is put on the outside of the nipple where it goes into the cast. And if it is used often and with time to penetrate.
Everybody don't have tourches and it is very dangerous that much heat in the area of the house where the framing is and other combustable material.
I like that tool.
Old 01-25-2010, 11:10 AM   #10
Rewards Points: 79
I like that tool.
I could get my hands on a torch, but that's a last resort. I've used P'Blaster on identical nipples in cast iron and after a few treatments over a few days, they have twisted off without incident, given enough leverage.
That internal wrench looks good. Not cheap though at about $70. I found a cheapo chain wrench that works with a 1/2" socket rachet. If I put a 12" extension on my breaker bar, it might just do it. I'll keep you posted.
Old 01-25-2010, 01:33 PM   #11
Bondo's Avatar
Ayuh,... I was lookin' for a crow's foot chain, or pipe wrench when I found the 1 pictured,....
I have Easy-outs quite Large, but nothin' That Large...
Old 01-25-2010, 01:46 PM   #12
Please do I like to hear the ending and I always learn something.
Sounds like a plan with that wrench setup. Good Luck
Old 01-25-2010, 01:48 PM   #13
Not really a quote but a question, enlighten me what is a Master General ReEngineer?? And is there a Degree with that title?? Thanks.
Old 01-25-2010, 08:19 PM   #14
Bondo's Avatar
Ayuh,.... From the University of Life,...
Got a Doctorate in makin' everything I own,... Better...
Old 01-26-2010, 01:14 AM   #15
Rewards Points: 79
Here's what happened: I bought this (http://www.harborfreight.com/cpi/cta...emnumber=97073) and I actually got it to grip the pipe and I was turning it with my 1/2" ratchet and about 4 feet of pipe for leverage. It absolutely would NOT budge, despite being dosed with P'Blaster for 3 nights in a row. The nipple began to collapse in on itself, but I keep pulling, then the chain wrench snapped in 2 places -- that's what I get for buying a $5.99 wrench at Harbor Freight!
Tried my other wrenches, no luck. So I got out the reciprocating saw and followed the advice I'd read from other posts and cut the pipe lengthwise into slivers and then twisted them out. I was left with just the threads still in place, and I had my doubts, but I got an old screwdriver and began hammering an edge. It slowly started to push in and behold, I was actually able to twist the remaining bit of pipe out! To God be the glory!
All that took me about 2.5 hours this evening. The threads on the cast iron actually are in great shape, I couldn't believe it. But the trap itself was filled quite a bit with debris -- iron filings and even gravel, surprisingly! I guess over the past 50 years, things fell down there and couldn't be fished out.
I used a telescoping magnet to pull all the iron stuff out, and then vacuumed what I could out. Ironically, after all that work, I'm thinking I should just jackhammer out the floor a bit and remove the whole trap and put in an ABS one with a Fernco coupling! I think the trap is fine but it would only take a few hours and it would be brand-new.
Anyways, thanks for all the encouragement and advice -- with this chatroom, I feel like I can do just about anything now!
Recessed Lighting Removal? kennykenny Electrical 12 02-19-2013 07:12 AM
How tight can a brass nipple be installed? darsunt Plumbing 6 12-20-2008 09:09 PM
dead-end nipple before a gas appliance amakarevic Plumbing 14 11-02-2008 09:12 AM
Lead paint removal Luken8r Painting 3 05-15-2008 07:05 PM
Recessed light plan foiled? kcrossley2 Electrical 8 03-14-2007 11:08 PM
