Old 10-25-2009, 09:36 PM   #1
Default recaulking kitchen sink
On tenant's departure I find that the caulk around front lip of enamel kitchen sink has peeled away. The iron below the enamel has rusted and stained the white tile which tenant has then painted white to make it look better..
The sink seems solid. How do I properly remove the rust before recaulking the sink?
diylandlady is offline   Reply With Quote
Old 10-25-2009, 10:12 PM   #2
Residential Contractor
Pictures would help us help you.
rselectric1 is offline   Reply With Quote
Old 10-27-2009, 04:05 AM   #3
JDC
Plumbing Contractor
JDC's Avatar
Go to the hardware store and get a product called Iron Out. Should take care of that rust problem.
JDC is offline   Reply With Quote
Old 10-27-2009, 10:05 PM   #4
Thank you very much, JDC. I will try that.
Old 10-29-2009, 09:26 PM   #5
Household Handyman
In my "Household HandyMan" business, I have landlords that I keep up their rental properties. You're problem is one that I run across two-three times a year. IMO-there are two ways to approach this problem: The "continuous repair" method, where you will be caulking this area, and others for a long time. OR: The "Do-It-Right" method, which should/will gain you long term usage of this sink. I personally do not like using "caulk" to seal a sink to a counter top surface. I prefer "rimming" a sink, which is to use plumbers putty to create a seal all the way around. With the rust being a factor here, I suggest removing the sink (I know, it's not really easy), removing all the rust you can, and then coat the areas which were rusted with enamel sink repair. This material for repair comes in a small bottle, and usually you can get a close color match. Once the rust area is repaired, the bottom of the sink rim is cleaned, the counter top has all the old sealant scraped off and cleaned, it's time to rim the sink. I'll not go into details as to how to do this, Google it and you can learn, it's not complicated. You will have a much better seal to the sink which will last a long time when done correctly. Good Luck, David
More On This Topic
Hi, this is Jon on behalf of Expert Village in this video clip we'll be checking the caulking on our doors and windows. What you want to do is take a look at the joints where your window meets your house. At that seam there should be caulking and you... Read More »
When you’re caulking around a tub or a sink, it’s important to dig out the old caulk first, especially if it’s grown some mold, because that will just go through the new caulk. So, it’s a little bit tedious, but it really is... Read More »
Nothing is more annoying than bugs in a home. The following will help prevent and detour any unwanted visitors. Read More »
How to Caulk a Kitchen Sink
How to Caulk a Kitchen Sink by Expert Village
Once you have all the plumbing done and all the water connected up, you want to take some 100% latex silica caulking, and press it hard up against the edge of the sink. Let it get everywhere. Make sure you press it up against the sink really hard. Once... Read More »
Named after their tendency to excavate extensive galleries in wood beams, the carpenter ant rarely causes structural damage to a well maintained home. Still, it's important to prevent and repair any damage to wood caused by carpenter ants, so follow... Read More »
Need help re-routing kitchen sink vent Fingers Plumbing 11 10-23-2009 05:17 PM
Smell Under Kitchen Sink mamaerin General Discussion 4 09-23-2009 01:01 PM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 07:41 PM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 07:53 PM
Kitchen sink recommendations? pweller Plumbing 4 07-08-2008 10:43 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
