Old 01-24-2010, 07:37 PM   #1
Reboot:small bathroom rough-in, Help please.
Hi all,
I posted a few pictures of my rough-in a few days ago. Changed some things up due to some suggestions. I'm reposting with new pictures of the changes I've made.
I've taken out some of the 90's for the pex.
I've put the toilet drop ear on the left of the toilet.
Vent is now slanted upward towards stack.
The T's are on the right way for the venting.
The Y for toilet drain is now up and in the right position instead of on it's back.
The pipe between the shower control and the spout is now brass, instead of PEX.
I left the vent in the middle in. Some have said it is not necessary. I thought it was venting the toilet. I changed out the T and put in a Y, anyway, as per suggestions.
Now I don't know what to do about the tub drain and vent. I do think the hole I cut through the joist is probably too high and the inspector is not going to like it. I think I'm going to cover it over with plywood and give him a line about trying to reinforce or beef it up for some reason or another.
I've change out the y for a t as suggested and that has lowered where the pipe will go into by about an inch. SOme have said that I should just drain the tub right into the stack, but then how do I vent it. The home depot guys said use a cheater vent. Is that an option?
I have not cemented the ABS and I have not crimped the PEX together.
Anyway I look forward to any comments you might have about anything. Don't hold back and it's really helpful if you explain how it could be done right, instead of just saying it's wrong.
This is my first time roughing in a bathroom for my grandmother who can't afford a plumber, but I'll probably pay for a plumber to come in and take a look before I have it inspected. '
Thanks again, everybody.
Reboot:small bathroom rough-in, Help please.-1-overview.jpg   Reboot:small bathroom rough-in, Help please.-2vanity.jpg   Reboot:small bathroom rough-in, Help please.-3-toilet.jpg   Reboot:small bathroom rough-in, Help please.-4tub-shower.jpg   Reboot:small bathroom rough-in, Help please.-5toilet.jpg
Reboot:small bathroom rough-in, Help please.-6leftoftoilet.jpg
Bobiggs is offline   Reply With Quote
Old 01-24-2010, 07:45 PM   #2
I forgot to mention that the stack to the ceiling is still in a few pieces because I have to figure out what i'm doing with the tub before I know how long the pieces have to be, hope that makes some sense.
And some more pics
Reboot:small bathroom rough-in, Help please.-7tub-drainvent.jpg   Reboot:small bathroom rough-in, Help please.-8drainvent.jpg   Reboot:small bathroom rough-in, Help please.-9stack.jpg   Reboot:small bathroom rough-in, Help please.-10stackdrain.jpg   Reboot:small bathroom rough-in, Help please.-11tubdrainvent.jpg
Old 01-24-2010, 11:04 PM   #3
retired elect/hvac/plumb
plummen's Avatar
venting looks much better! i would of left wye for toilet on side though,too many drops/bends allow solids to drop out and cause clogs down the road in my opinion
plummen is offline   Reply With Quote
Old 01-25-2010, 06:05 PM   #4
I would look at actually beefing up that joist with the big hole rather than covering it with plywood.Possibly sistering with same dimension lumber and through bolts, reaching in as far as you can and making it as long as possible. This joist is going to hold up a tub full of water.
daveb1 is offline   Reply With Quote
Basement bathroom rough in efrobert Plumbing 2 06-23-2011 05:54 PM
Basement bathroom rough in plumbing ferris13 Plumbing 5 09-28-2009 11:06 AM
basement bathroom rough in - framing questions twobabieslater Building & Construction 2 12-29-2008 03:56 PM
Bathroom rough in shamrock_94 Plumbing 6 07-12-2008 11:33 PM
Basement Bathroom Rough In snowwhite49 Plumbing 2 05-26-2008 10:11 AM
