REALLY Slow Draining Kitchen Sink! - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-04-2006, 11:21 AM   #1
REALLY slow draining kitchen sink!
The sink is new (45cm diameter round) and worked fine on day 1. Now however (day 2) it has decided to drain really slowly - like it is blocked. I have taken the u-bend and pipes apart and there is no blockage. The only think I can think of is that there is a blockage in the pipe further down the line (in the wall) - if so maybe a plunger will work.
Any ideas?
stenton is offline   Reply With Quote
Old 12-04-2006, 04:34 PM   #2
Was the drainline for this sink disconnected for a few days or weeks? If so, anything that was clinging to the inside of the pipes may have dried out and fallen into the main part of the line causing a blockage. You may need to snake the line out.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 12-04-2006, 05:45 PM   #3
Long-Time DIYer
Mike Swearingen's Avatar
My solution has always been to try a good enzyme-based drain cleaner first, such as DrainCare, NOT a caustic-based such as Drano.
It won't harm the sink or fixtures, but it WILL eat out all organic clogs(grease, food particles, etc.) that get built up in a kitchen drain line.
Run warm water down the drain, pour in the drain cleaner as directed, allow to eat overnight, and then flush with very hot water the next a.m.
I use a kettle of boiling water the next morning to first get it going and then follow that with the hot water-only faucet until it runs clear.
Good Luck!
EDIT: Never pour grease or oils down a sink. Clean out pots, pans and skillets into the trash of greasy matter. Those are the worst cause of clogging.
EDIT: Aha. There is that majakdragon grasshoppa again! LOL
Mike Swearingen is offline   Reply With Quote
New kitchen sink issue Grebus Plumbing 2 01-21-2016 10:22 AM
Kitchen sink jonnyjonny_uk Plumbing 6 11-20-2006 06:43 AM
Sink or No Sink in Kitchen Island? Not Sure Plumbing 4 08-29-2006 07:37 PM
stainless steel kitchen sink KANUTTER Plumbing 6 01-09-2006 03:42 AM
Replacing kitchen sink knob? Pikaia Plumbing 4 06-09-2005 09:43 PM
