Re-using A Drain Cleanout - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-19-2010, 05:45 AM   #1
Rewards Points: 12
Re-using a drain cleanout
Hello:
I'm installing a small bar with a sink in a basement rec room. The bar will be against a wall, open on the left, and up against a utility closet on the right. The ceiling is finished. There's a small access panel directly above where I need to install the cabinets. The access panel is for access to a drain cleanout. I want to do two things with this cleanout. First, I want to close off the access panel, so I was thinking of connecting a drain line to the cleanout and running it about 8' to the right to the utility closet. The cleanout would now be in the utility closet. I also plan to have the bar sink next to the utility closet. I'll place a sanivite pump in the utility closet, the bar sink will drain into the sanivite. Can I pump the waste from the sanivite up to the new line I just attached to the cleanout? I'll add a new cleanout where the sanivite and new line connect. It would save me a lot of time and make things a lot easier.
Thanks.
mpt1123 is offline   Reply With Quote
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 01:46 PM
Connecting Outside Sink Drain to Main Cleanout dancobian Plumbing 7 06-03-2009 06:26 AM
3.5'' Brass Drain cleanout cover jeffmn Plumbing 6 01-13-2009 07:37 AM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 07:10 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
