Re-using Compression Nut And Sleeve On Another Brand Of Shut Off Valve? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-19-2009, 01:46 AM   #1
Rewards Points: 278
Re-using compression nut and sleeve on another brand of shut off valve?
Hi, I just installed new faucet shut off valves. After a tough time pulling the old sleeve off I found deformed pipe so I cut off about 1".. but next time it will be too short and will require soldering a longer pipe.
I installed new ball valves and these balls attempts to shut 2 outlets, there are problems with these valves, one spray water and one drips. I don't know if the manufacturer (Watts) has a different idea about shutting off water than I do, but I am not ready for the faucets yet so this dripping is not acceptable.
My question is that can I keep the Watt's nut and sleeve to install another brand of shut off valve, or should I pull them off again? Because I was thinking I wouldn't need another valve for 20 years+, I tightened them pretty good, so I am afraid I might have deformed the pipe or something. I should have known better since they were less than $10.
The spacing before the sleeve could also be different so am I in trouble here?
Thanks in advance.. very frustrating day of DIY...
DIYGST is offline   Reply With Quote
Old 01-19-2009, 06:34 AM   #2
In general, you can usually swap the valve without replace the nut/compression ring. These components have become largely standardized. That is not to say it will always work. I usually apply a dab of plumbers grease to the nut threads and the ring before installing. This allows you to tighten them a bit easier and tighter.
Old 01-19-2009, 07:07 AM   #3
Long-Time DIYer
Mike Swearingen's Avatar
I almost always use the old nut and compression ring when replacing a compression fitting valve.
The brass ferrule ring actually does the sealing in a compression fitting(not the threads) so Just Bill's sealing tip should do the trick for you.
I always smear a little clear silicone caulk on the ring, tighten it up (with a backup wrench) and never have a problem.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 01-19-2009, 09:57 AM   #4
Rewards Points: 278
Thanks, what is Plumber's grease? That's the problem I was having, one did not turn as much as another and the turning action was jerky. I was thinking antiseize or something but it's for the kitchen.
Can I use some NSF food safe silicone grease and have it work the same way?
I am thinking about it and it's the tiny TAPER on the front edge of the brass ferrule that seals the water ? So as long as I tighten a smudge more than the previous faucet, I should be good?
Old 01-19-2009, 12:44 PM   #5
Rewards Points: 278
I have bought the plumber's grease, seems like good stuff, It really helped me tighten the nut smoothly
