Re-routing Washer Drain - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-02-2009, 03:01 PM   #1
re-routing washer drain
I want to move my washing machine into a large closet that is off of one of my bathrooms on the 1st floor. Currently the washer is in an utility room that is off the kitchen however I am remodeling the kitchen and want to incorperate that space into the design so I have a larger kitchen. My house was built in 1935 and when the washer was installed they ran the drain line and connected to the kitchen sink drain. Works fine except for some gurgling noise which we are OK with. My question is, if I move the washer to the closet off the bathroom, can I run the drain and connect it to the drain for either the bathroom sink or the shower? The distance would be aproximately 5-6' (which is the distance it now runs to the kitchen sink). I have done some basic research and know that I need to install a trap and run the pipe so that there is 1/2" of slope for each 1' of distance. I already have water in the closet as my water heater is in this location so I just need to add the drain and electrical connections. Any thoughts? thanks for any responses.
71Whaler is offline   Reply With Quote
Old 09-02-2009, 07:56 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
I would tell you first the a wahing machine needs to be a 2" line and you might be able to connect it to the shower drain with a sanitary "T"
Also slope is 1/4" per foor and any trapped fixture with a 2" line max run to a vert stack is 8".
OH, don't connect it to a sink or lav drain because a lav drain is 1 1/2" pipe
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 09-03-2009, 11:30 AM   #3
Most newer codes require 2" pipe for washer drains. Reason is that newer washers have stronger pumps and 1-1/2" will back-up or clog faster. Never heard of 1/2" slope on drain piping for 2" or smaller drains. Used to be 1/8" per foot but increased to 1/4" per foot later. I agree with Plumber 101 on the best connection.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
relocating washer drain idodishez Plumbing 7 04-21-2009 08:36 PM
Water heater drain pan - can I drain into the washer drain? cjartguy Plumbing 7 04-15-2009 02:34 PM
washer drain is draing slow mrmordun Plumbing 13 03-08-2009 10:45 PM
Washer Drain Help Needed PatDaddy Plumbing 4 05-05-2008 10:35 PM
Washer drain peloncito Appliances 7 08-04-2007 12:56 AM
