Re-routing Kitchen Drain, Do I Need To Bring To Code? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-14-2012, 09:10 AM   #1
Re-routing kitchen drain, do I need to bring to code?
The old route for our kitchen sink was problematic and we want to re-run via a different path in the basement which will make for a shorter run. I know that we have to use a certain slope for proper drainage (1/4" p/foot I believe) but my problems are:
Our current drain is 1-1/2", I believe code is now 2". By disturbing this, I assume I will have to upgrade to the 2".
Our current sink configuration does not have a vent, I assume when the house was built in 1975 or thereabouts that it passed code and then it was OK, now if I am rerunning the drain line and disturbing all this, will I now have to add a vent pipe for the kitchen sink?
~Sue
suzcomptime is offline   Reply With Quote
Old 07-14-2012, 11:29 AM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
You don't HAVE to do anything.
That said, yes, the minimum size for a kitchen sink drain is now 2" It would be a good idea to upsize since you are going to the trouble of replacing it.
You should also add a vent. If the wall isn't open, and your area allows it, you COULD use a studor vent. I prefer a conventional vent whenever possible, but there are situations where the studor vent comes in handy.
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
TheEplumber (07-14-2012)
Old 07-14-2012, 11:42 AM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 350
Just to add to what Allen said- if you increase to 2"-and you should if possible- be sure you do not decrease back to 1.5" when you tie into the main. You must replace the fitting (wye or tee) in the mainline also.
The Following User Says Thank You to TheEplumber For This Useful Post:
VIPlumber (07-15-2012)
Lowering kitchen drain pipe - PVC LeviDIY Plumbing 22 08-21-2016 05:23 PM
Routing new drain Jack E Plumbing 7 03-24-2010 04:06 PM
Kitchen Drain Dilemma DIYaholic Plumbing 4 01-13-2010 09:23 PM
Clogged kitchen drain swoop Plumbing 3 12-28-2009 11:34 AM
Anyone know if it is code for a utility room floor drain? tigerbalm2424 General DIY Discussions 3 10-17-2007 11:48 AM
