#1 |
Re-Plumbing Drain
I'm replacing my vanity top and want to swap out the old galvanized steel drain pipe; judging by the water damage underneath the taped up part, this has leaked a lot in the past. What's the best way to replace this? (I want to use PVC.) I checked in the basement and the drain pipe never goes through the floor, I'm guessing it must go through the wall and connect to the cast iron drain pipe where the toilet is about 3 feet to the left. Should I just plug the old pipe going into the wall, drill a hole through the floor and bottom of the vanity, and add a T to another existing drain pipe? Whoever installed the vanity didn't center it very well and it'll require lots of angles to fit properly.
#2 |
Re-Plumbing Drain
There should be a nipple(1 1/4) in the wall elbow. It is likely rusted at the threads and should be replaced. They are often very hard to get out, sometime requiring removal of the vanity top for better access. Once out, a new version made with PVC can be installed. Clean out the elbow, they are often partially clogged. Don't forget to wrap the threads with teflon tape or I use plumbers putty. The rest should be easy, using the old as a guide. You need a new P trap with a slip loint connection, probably a 45(other angles available) out of the nipple, and you are ready to go. All of the old chrome looks bad so replace everything.
#3 | |
MarginallyQualified
Re-Plumbing DrainQuote:
If this is the only problematic drain in the house consider yourself lucky. Plan to OPEN THE WALL behind the vanity some in order to inspect and (likely) have room to replace the (tee) fitting your drain attaches to. If your luck holds... you'll be able to replace the threaded nipple with a PVC threaded adapter and then attach your vanity trap fittings to that. |
#4 |
Re-Plumbing Drain
So it'd be easier to cut through the bottom of the vanity and floor and run new pipe?
#5 |
call me E
Re-Plumbing Drain |
#6 | |
MarginallyQualified
Matt, in the first post you said: "I'm replacing my vanity top and want to swap out the old galvanized..." When you have the top off... also pull the vanity cabinet away from the wall. AT THAT TIME you can inspect and evaluate... then do what is needed. Until you get in there it is all supposition. When you're all done you can reinstall the cabinet and your new top. hth |
#7 |
Re-Plumbing Drain
Well, I'm just thinking it'll be easier to drill a hole as opposed to tearing up a wall. The drain line for the shower runs right under the sink in the basement so it'd be easy to tap into that (and be connected to the vent).
I'm just figuring once I pull the vanity away from the wall it'll just be a pipe sticking out of drywall and won't tell me anything. |
#8 | ||||
MarginallyQualified
it is all supposition. Plan to OPEN THE WALL behind the vanity some in order to inspect and (likely) have room to replace the (tee) fitting your drain attaches to. Quote:
you may have to open the floor as well. Drywall repair is the easy part. Again, until you open up the wall to get in in there and see... it is all supposition. Quote:
it is all supposition. Last edited by TarheelTerp; 01-22-2012 at 10:07 AM. |
#9 |
retired elect/hvac/plumb
Re-Plumbing Drain
If the line doesnt go through the floor id be willing to bet theres just a 90 in the wall tied to a pipe running laterally over to the stack.
Id pull the vanity out and just open the area directly around the fitting coming out of wall to check things out first,easy to hide behind the new vanity
#10 | |
Question though... I've read stuff that says not to use a female PVC connection on a male metal connection. Is this only for pressure applications? Because that was the only way to hook this up. Last edited by matt151617; 02-17-2012 at 07:33 PM. |
#11 |
Re-Plumbing Drain
Your info is wrong. It's fine to go PVC to metal drains.
It would have been far better to remove all of that old steel pipe before it plugs up or starts leaking (and it will at some point). |
| Display Modes | |
| Scupper drain installation advice needed | miamicuse | Roofing/Siding | 9 | 02-11-2012 10:59 AM |
| Double Bowl Kitchen Sink Drainage Problem | PeteW | Plumbing | 16 | 09-05-2011 10:41 AM |
| Basic Question on plumbing (planning to unclog bathroom sink drain) | babyfishmouth | Plumbing | 1 | 07-31-2011 01:14 AM |
| WC Plumbing Code Violations??? | silvajus | Plumbing | 2 | 07-30-2011 08:07 PM |
| The Bioswale, french drain, deck, drainage dilemma (long) | seabright_sc | Building & Construction | 2 | 01-05-2008 04:37 PM |
