Re-installing saddle valve on newly installed water heater connections
Irrespective of whether a saddle valve meets the minimum code requirements in you location, many that I see eventually leak. Installing a tee and a conventional valve is a more reliable approach.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
