Re-circulating Pump Noise - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-27-2013, 03:51 PM   #1
re-circulating pump noise
Replaced re-circulating pump in return line of a domestic hot water heater system. Pump is running hot to touch and is making excessive amount of noise. Is it likely I didn't remove all the air from the enclosed system, or could there be other reasons for the noise? Thanks for any suggestion to correct this problem.
Ron S.
Ron S. is offline   Reply With Quote
Old 08-28-2013, 09:49 PM   #2
Master Plumber
Javiles's Avatar
Rewards Points: 990
couple reasons for the noise, need more details a pic would be helpful
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Aquatec Permeate Pump Noise, Reverse Osmosis nissmo66 General DIY Discussions 2 01-16-2012 02:20 PM
Intermittent submersible pump fault esquilax Electrical 5 09-30-2011 04:56 AM
Suddenly Heat Pump making rat-a-tat-tat noise mgroves HVAC 1 12-20-2010 01:49 PM
wood boiler controller for circulating pump frank charles HVAC 4 11-22-2010 04:43 PM
sump pump continuing running deck hand Plumbing 2 01-16-2008 05:35 PM
