Old 09-07-2009, 01:35 PM   #1
Re-assembling tub faucet: mysterious O-Ring
Hello-
I am putting my tub faucet back together after tiling and there's an o-ring that I can't remember where it came from. I believe it was in the location I have it now but I don't know what it would be for. See the photo, it's the o-ring that I currently have past the bonnet ring.
Anyone know? Thanks!
While I'm at it, what kind of caulk should I use for this plate? Do I only caulk in the small hole, or around the outer edge as well?
Re-assembling tub faucet: mysterious O-Ring-photo-3-.jpg   Re-assembling tub faucet: mysterious O-Ring-photo-4-.jpg
99miles is offline   Reply With Quote
Old 09-07-2009, 09:58 PM   #2
that oring belongs right there. put it just behine that nut the slip the trim on.. as for caulk you can use kitchen and bath caulk and just caulk arounf the outside of the trim plate.
plumber Jim is offline   Reply With Quote
Old 09-07-2009, 10:02 PM   #3
thanks Jim! i'm curious what it's purpose is, it still doesn't seem like it actually does anything?
Old 09-07-2009, 10:09 PM   #4
GC/Master Plumber/Mech
It centers and holds the trim cylinder
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 09-07-2009, 10:17 PM   #5
general contractor
A.W.Davis's Avatar
By looking at the photo, it appears the o-ring does no good resting on the valve body. Without being physically present or having manufacturer specs it's tough to speculate where the o-ring goes!
What's the name of the shower valve manufacturer?
As far as caulking we usually use a grout caulking that matches the existing grout color around the finish trim.
A.W.Davis is offline   Reply With Quote
Old 09-07-2009, 10:41 PM   #6
I think the o-ring is correct but i have another question for you. It might just be the picture but did you leave enough room for the screws that mount the plate.
paul100 is offline   Reply With Quote
Old 09-08-2009, 02:30 AM   #7
Yes, there is enough room for the screws
It's a Delta 1400 Series.
Thanks, all!
Another "Kitchen faucet replacement" thread! :) emperor_black Plumbing 3 07-27-2009 11:44 PM
Wax Toilet Ring Question cabinetman Plumbing 2 05-31-2009 11:12 AM
Washing Machine Faucet handy man88 Plumbing 5 03-23-2009 02:25 PM
No hot water pressure at kitchen faucet tracker883 Plumbing 2 12-30-2008 06:10 AM
Faucet Repair Questions? mfleming Plumbing 3 05-07-2008 10:44 AM
