-   -   Re-assembling tub faucet: mysterious O-Ring (http://www.diychatroom.com/f7/re-assembling-tub-faucet-mysterious-o-ring-52480/)
99miles 09-07-2009 12:35 PM
2 Attachment(s)
Hello-
I am putting my tub faucet back together after tiling and there's an o-ring that I can't remember where it came from. I believe it was in the location I have it now but I don't know what it would be for. See the photo, it's the o-ring that I currently have past the bonnet ring.
Anyone know? Thanks!
While I'm at it, what kind of caulk should I use for this plate? Do I only caulk in the small hole, or around the outer edge as well?
plumber Jim 09-07-2009 08:58 PM
that oring belongs right there. put it just behine that nut the slip the trim on.. as for caulk you can use kitchen and bath caulk and just caulk arounf the outside of the trim plate.
99miles 09-07-2009 09:02 PM
thanks Jim! i'm curious what it's purpose is, it still doesn't seem like it actually does anything?
Plumber101 09-07-2009 09:09 PM
It centers and holds the trim cylinder
A.W.Davis 09-07-2009 09:17 PM
By looking at the photo, it appears the o-ring does no good resting on the valve body. Without being physically present or having manufacturer specs it's tough to speculate where the o-ring goes!
What's the name of the shower valve manufacturer?
As far as caulking we usually use a grout caulking that matches the existing grout color around the finish trim.
paul100 09-07-2009 09:41 PM
I think the o-ring is correct but i have another question for you. It might just be the picture but did you leave enough room for the screws that mount the plate.
99miles 09-08-2009 01:30 AM
Yes, there is enough room for the screws :)
It's a Delta 1400 Series.
Thanks, all!
