Ran Out Of Pitch For Drain Line - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-24-2013, 08:28 AM   #1
Ran out of pitch for drain line
I recently hacked up 15 feet of concrete to run a new drain line for a bathroom I will be installing. I started from the main stack and run the 4" pvc from there, by the time I reached the toilet, I am about a half inch to high once I put the flange into the 90. I was wondering if anybody ever cut the 90 back so that the flange could slide further down into the 90?
marty813 is offline   Reply With Quote
Old 09-24-2013, 08:40 AM   #2
If it is really only 1/2 inch, you should be fine, go ahead and cut it. Anchor the flange to the concrete.
broox is offline   Reply With Quote
Old 09-24-2013, 12:25 PM   #3
Rewards Points: 352
you could run 3" pipe instead
plumberinlaw is offline   Reply With Quote
Old 09-24-2013, 06:03 PM   #4
Rewards Points: 1,958
Use a 4 by 3 coupling run the toilet and vent in 3 inch... Vent that thing that allows stuff to have air...
Old 09-24-2013, 09:10 PM   #5
Rewards Points: 582
yes we have cut hubs before...but I don't reccomend it ..as mentioned reduce to 3" it should just make it..ben sr
Gas dryer - installing flexible gas line mspmatt Plumbing 11 12-30-2011 04:32 PM
tapping water line for new line KarlJay Plumbing 5 07-28-2010 09:30 AM
New ICe maker line causes ice to taste like rubber speedster1 Plumbing 5 06-27-2010 08:09 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
electric line and gas line couch potatoe Electrical 17 09-30-2008 10:43 PM
