Raising A Toilet - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-09-2011, 01:34 AM   #1
Question
Raising a toilet
I plan to raise the toilet by placing under it a 4" wood base cut to the toilet base shape and proper hole cut. But the drain end coming up must have a similar 4" extension. Do I just join a short chunk of drain pipe to it? Any problems with my idea in general?
Wayne Cooke is offline   Reply With Quote
Old 10-09-2011, 06:52 AM   #2
DIY staff
Rewards Points: 7,174
Unusual---Can you remove the existing flange and properly attach a length of pipe and a new flange?
Old 10-09-2011, 07:11 AM   #3
the Musigician
DangerMouse's Avatar
Why?
DM
Old 10-09-2011, 03:42 PM   #4
There are toilets out there that are 17" above the floor, as opposed to the usual 15". I can't remember the exact name but I heard them called 'comfort height'.
As Mike stated you'd need to remove the existing flange, extend the drain, & then attach a new flange at the new height.
As Danger asked, why?
VIPlumber is offline   Reply With Quote
Old 10-09-2011, 04:44 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 452
and I thought you were a plumber
Old 10-09-2011, 05:56 PM   #6
DIY staff
We call the "High Riders"
Old 10-09-2011, 06:03 PM   #7
Doing it myself
Alan's Avatar
Rewards Points: 2,086
They're all coming out with their own name for "ADA" because we don't want to offend the handicapped folks who need to use them
Journeyman Plumber
Old 10-09-2011, 08:27 PM   #8
Well I did stay at a Holiday Inn recently...
Old 10-09-2011, 09:08 PM   #9
Mark Potter's Avatar
Rewards Points: 150
Funny.. I worked maintenance for holiday inn but that was many many moons ago lol
H|P Capital
Mark Potter is offline   Reply With Quote
Old 10-10-2011, 11:17 AM   #10
Rewards Points: 1,574
Perhaps more than you'd want to know on sitting vs. squatting:
http://www.slate.com/articles/health...sit_there.html
bob22 is offline   Reply With Quote
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
Need help with toilet to flange problem if raising flooring riverjamie Plumbing 9 02-13-2010 03:19 PM
Toilet issue: Shims, wax, general disarray. dawho1 Plumbing 8 01-23-2010 08:38 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
