I am trying to install a fiberglass molded shower base by EL Mustee. The drain is molded into the piece, and there is a hole where the 2" drain pipe should come through. Then there is a gasket that fits tight around the pipe and shower base molded drain.
When I removed the old shower base, I had to raise the subfloor, so that now the 2" pipe sits about 3/4" in below the top of the subfloor. Is there an easy way to raise this pipe...or another type of shower seal that I can use to go down that far..? I spoke to somebody at home depot, who sold me a threaded drain seal...but it was too big for the Mustee drain opening.
Thanks!!
Thanks!!
