Raising A Kitchen Sink In Order To Paint Counters - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-22-2012, 03:57 PM   #1
raising a kitchen sink in order to paint counters
I am wanting to raise my sink by just 1/4" or so because I plan to apply Spreadstone to my counters and would like for the product to go alittle under the sink. This photo shows the screws under the sink. Do I unscrew these abit and then use a flat screwdriver to pry the sink up slightly? there is caulk to seal it so I will probably need to run something around it to release the hold. Any opinions of best way to do this would be awesome!
annie68164 is offline   Reply With Quote
Old 03-22-2012, 04:12 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 676
Loosen the screws so the clamp is loose. Then quarter turn the clamp and slid it to the end of the track or to a notch partway down the track- whichever is convenient. Be sure to cut the caulking bond at the sink rim(if there is one) otherwise you might crack the formica surface
The Following User Says Thank You to TheEplumber For This Useful Post:
plumberman134 (03-22-2012)
Old 03-22-2012, 04:17 PM   #3
You pretty much nailed it.Im guessing you know to disconnect the drain and supply lines though.If you have chrome or plastic supply tubes they might be a little short after you raise the sink,same goes for the drains but those have play to make up the 1/4 inch.Might not be a bad idea to pick up braided steel lav supplies
plumberman134 is offline   Reply With Quote
Old 03-22-2012, 04:26 PM   #4
I have plastic pipes, they seem pretty flexible, I'm assuming they can handle the sink going up 1/4". Thanks for telling me how to manage those clamps, wasn't sure exactly how they worked. So I will loosen the screws, slide the clamps off the track or turn them so the sink has clearance to lift, hope I got that right. Thanks!
Old 03-22-2012, 05:06 PM   #5
Plumber
Rewards Points: 676
Thats about it
Word of caution though- you may find yourself folded up like a pretzel getting to a couple of them
Old 03-22-2012, 05:11 PM   #6
Rewards Points: 13,712
Just as easy to just remove the whole sink and then you will know the whole surface is covered.
All the same steps you going to do anyway.
Old 03-22-2012, 05:33 PM   #7
Originally Posted by TheEplumber View Post
Thats about it
That's funny you say that- took a good look under the sink and thought how it was going to be interesting trying to get to all those! I may need to see the chiropractor before I'm through with this project.
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 08:00 AM
Wrong Paint on Kitchen Cabinets? cbarker Painting 6 02-24-2012 02:53 PM
help! bring my kitchen together NewlywedKristin Interior Decorating 10 10-26-2011 01:08 PM
Painting patch in bathroom ohman Painting 4 09-15-2010 10:09 PM
Cast iron self-rimming kitchen sink & granite tile ILjXYZ Kitchen & Bath Remodeling 1 01-03-2009 05:53 PM
