Raising An Electric Water Heater - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-05-2010, 12:09 PM   #1
raising an electric water heater
Hello,
My home inspector (new construction) suggested that we raise the electric water heater off the floor a few inches (on bricks or 2x4's). It is "not necessary, but a good idea." My question is: WHY is it a good idea? What will it buy us that leaving it on the ground won't?
Thanks in advance!
likarnold is offline   Reply With Quote
Old 08-05-2010, 12:22 PM   #2
If it sits right on concrete...or the floor, a small leak/moisture can cause the bottom to rust out over the years
The Following User Says Thank You to Scuba_Dave For This Useful Post:
likarnold (08-05-2010)
Old 08-05-2010, 02:49 PM   #3
Owner
LateralConcepts's Avatar
It should not sit directly on a concrete floor. I would suggest a high-density styrofoam pad. In addition to keeping the bottom of the tank rust free, it will also help with efficiency by not allowing energy (heat) loss from cool dense concrete. I have also heard it can shorten the life of the elements. Similar to placing a car battery on bare concrete would kill the battery. (not sure how much truth there is to that though)
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
The Following User Says Thank You to LateralConcepts For This Useful Post:
Gary in WA (08-05-2010)
Bosch 1600H Tankless Water Heater natemclain HVAC 13 08-24-2009 11:33 AM
Multiple hot water heater issues a-6intruder Plumbing 8 01-16-2009 06:58 PM
Water heater drain mechanism (10 year old) guptaalok Plumbing 1 01-02-2009 06:40 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
