It is two solid different concrete pads, two different levels. I have removed the wall in between them. Rebuilt the exterior walls. I am going to put a sink on the left side far concrete pad room(Centered on the wall of that room "Kitchen"). Drain pipe for sink/dish washer. How much would I need to build the floor up for a good drain.
Also I will be making both concrete pads one all the way across. I was thinking of making like a deck structure made of 2x4 or 2x6 if needed.
I'm not a pro plumber ... You might post in the plumbing forum ... but my understanding is that one should pitch drain pipes 1/4 inch per foot...and may go down to 1/8 inch per foot if the pipe is upsized one size.
Now I may be wrong on this. Again, the plumbing forum will probably give you some pro answers
I will not be leveling up to the floor height of the 24'x36'. As for leveling the concrete pads up to one level just high enough to run a drain+supply line atleast 1.5" above the floor when it comes out of the 24'x36' so it misses those floor truss plates, if not ill be drilling a hole threw a horizontal plate :/
Anyhow to finally answer it. I was planning on using 2x4's or 2x6's where the kitchen will be and then use engineered header board for the bottom level???? And make a subfloor structure.
2x4,2x6,Engineer wood???? What type of wood would you all use?
If 2x6's were used for the top level concrete pad room. I would almost have a 15.5" level to come up to in the bottom level concrete pad room. I don't want the floor to bounce like a trampoline.
It will be a mixture of ceramic tile, carpet in the kitchen/high traffic area/living room which is the 2 concrete pads.
I would love to help you out- but I feel totally lost in your descriptions.
Maybe it's because I'm still on my first cup of coffee....
Your existing building drain under a slab?
Then saw cut the floor- run new 2" pipe to the sink location - grade it 1/4 " per ft- inspect it- cover and pour back the concrete.
Now you can do whatever you want with the floor heights.
It was also suggested to run 1/8" per . I advise against that on a kitchen line. Also, per UPC that can only be done on 4" and larger- perhaps your code allows it
No thats a 4 foot crawl space underneath the top 24'x36'. There are only the 2 slabs.
Im going to have a sub-contract plumber that Ive worked around to come in around wednesday of next week.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.5K members
Since 2003
