Old 11-17-2006, 10:31 AM   #1
Raised toilet flush problems
I have a new house and had a 6 litre raise toilet eljer I believe is the brand installed. It does not flush well and appears to not allow the 6 litres to past before the flapper covers the drain. I checked the flapper and all looks good. Is there an issue with this manufacturer and should I have the toilet change out for another or is there a fix?
ricgail is offline   Reply With Quote
Old 11-17-2006, 06:03 PM   #2
The flapper is raised by a chain/rubber strap and if it does not raise the flapper completely, it will close before the needed amount of water is down into the bowl. The chain should be "just" long enough to allow the flapper to seal, but no excess. Check to see if you have a lot of slack in whatever raises the flapper when you hit the flush handle.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 11-17-2006, 07:06 PM   #3
747
registered
747's Avatar
Thats like maj says readjust the chain.
747 is offline   Reply With Quote
Toilet Flush Handle skittlzski Plumbing 8 02-22-2009 11:29 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
toilet problems... sflamedic Plumbing 3 07-31-2007 11:15 AM
New Toilet Does Not Flush klugej Plumbing 3 04-30-2007 11:51 AM
Flush toilet, hear shower drain noise joedadog Plumbing 1 04-01-2006 01:52 AM
