Raise Shower Curb - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-04-2013, 08:44 AM   #1
Angry
Raise shower curb
I need to raise my shower curb from 4" to 6" without a major re-do...I tried to install sliding doors but because my side edges have a slight curve, exactly square doors won't fit properly. Shower one piece unit is a Aqua Glass.
I get water going under and out the shower curtain when we shower due to curtain "lift" when shower is running as well as the draw fan.
Any suggestions? I saw a curb overlay unit but it is meant to be used when building a new curb along with tiling on top of it.
eastsidehunky is offline   Reply With Quote
Old 03-04-2013, 08:50 AM   #2
DIY staff
Rewards Points: 7,174
A picture of the existing work will be needed-----
What is the shower base and walls made of?
Old 03-04-2013, 09:09 AM   #3
Rewards Points: 6,652
You can get custom made doors. Contact the local glass shop in your area that does this type of work.
Old 03-04-2013, 10:22 AM   #4
Doing it myself
Alan's Avatar
Rewards Points: 2,086
I like this idea better than adding 2" to the curb. If you try to raise the curb by 2" I bet your tile will look strange, and then all the time and effort you spent to make it look nice = wasted.
Journeyman Plumber
Old 03-04-2013, 10:23 AM   #5
Roofmaster
Rewards Points: 2,172
Certain Lift???
What is this? You actually think that your bathroom exhaust fan is sucking water out of your shower pan ????
Old 03-04-2013, 10:51 AM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 820
I think he means "Curtain Lift".....I get it with my shower curtain....but it's caused the convection from from the air heated by the water....hot steamy air goes up...sucks cold air at the bottom of the tub....I take pretty hot showers.
I also agree with the custom door approach.
You can get a tempered glass door from your local glass shop a lot cheaper than from shower door business....just make a cardboard cutout the exact shape you want...including holes for the hinges and pull....take it to them...they will cut out a 1/4" slab of glass...drill the holes and ship it off to get tempered....
I've made a couple of custom windows using tempered glass and I was amazed at how cheap it was...in on case, it was a bi-fold window....4 46"x10" panels (1/8" glass)....tempered...cost me $60.
Old 03-04-2013, 10:29 PM   #7
Rewards Points: 142
i want to see the "slight curve". and i want to see the frame for the door.
i will bet that the frame can be easily trimmed to fit. i had to do it once.
Fix'n it is offline   Reply With Quote
Tags
curb , increase height , shower
Basement bathroom shower remodel NewHomeDIYGuy Kitchen & Bath Remodeling 39 11-26-2013 11:20 AM
Curb for shower is close to heater, how to proceed? RyanD Building & Construction 6 01-19-2013 12:13 PM
Thinset over lath on shower curb? darsunt Remodeling 0 01-02-2013 12:03 AM
Complete bathroom redesign- need help with shower placement Liv Kitchen & Bath Remodeling 0 03-08-2012 01:00 PM
shower pan curb califmonster Building & Construction 2 07-31-2011 09:34 AM
