Rainwater Drainage - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-04-2012, 07:51 PM   #1
Rainwater drainage
I am experiencing flooding on my back patio. I have several solutions in place but the way my yard is set up - it continues to flood. I have installed a drain w/grate that drains to the front right side of my house. I have my gutter going to an underground pipe and flowing to the front left side of my house. But, I am on a cul-de-sac and have a pie shaped lot - with the back patio having a short backyard and level with the slab of the house. The person who installed my other fixes - says he's at a standstill because there is not enough slope to eliminate this water.
My question is - is there a "dirty water" sump pump that I could install myself that could be placed in a grate like drain - maybe battery run? Is this plausible or should I just call someone to install a pump? Thanks!
MaggieKay is offline   Reply With Quote
Old 10-04-2012, 08:06 PM   #2
Rewards Points: 558
You can try regarding. Pictures would be nice so we could get a better understanding of your situation.
epson is offline   Reply With Quote
Old 10-05-2012, 08:40 AM   #3
Rewards Points: 13,300
Really need that picture.
A slab at the same level as the house slab is never ever going to be a good thing.
Old 10-05-2012, 01:31 PM   #4
rainwater drainage
Thanks for answering - The first picture shows before I added the sidewalk - I thought it would help, not so much. But there is no way I can regrade - there is a sidewalk on one side that leads to the pool and there is no way I am going to divert water there. I can't grade it towards the back because there is a house behind me and I am sure they are having similar problems. The other side of the house is higher and grading it would cause the person on that side to flood. And because I am at the back of the cul de sac, street water flows my way. Would a sump pump help?
Old 10-06-2012, 08:19 AM   #5
Rewards Points: 1,448
A sump pump will not work unless it can send the water someplace else.
You may want to put a subtle berm at the front of your property so street water does not enter. The part put on your driveway would resemble a narrow "speed hump".
Where is water supposed to flow? Was there an intended swale through various neighboring lots ending up at the street somewhere else? Is there supposed to be a swale all around the cul de sac and continuing down the street where a sidewalk might ordinarily go?
Foundation Drainage bhry Building & Construction 3 09-23-2010 11:08 AM
Pool Surround Drainage Questions Ynot General DIY Discussions 3 06-07-2010 04:53 PM
The IPGC Drainage Pipe agster97 Landscaping & Lawn Care 0 07-09-2009 01:05 AM
Drainage & Sump Pump Advice FredAt Building & Construction 3 06-11-2009 10:14 AM
Drainage Tile and Retaining Wall nabz Landscaping & Lawn Care 3 05-25-2009 02:22 PM
