Rainsoft Water Softner - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-28-2012, 11:52 AM   #1
rainsoft water softner
The water keeps flowing. I turned off the power but to no avail. Whats wrong???
Thank you
jrenschen is offline   Reply With Quote
Old 04-28-2012, 11:58 AM   #2
Rewards Points: 13,296
Timer stuck in back wash? Hard to say from here.
http://www.rainsoft.com/products/problem-solving.cfm
Old 04-28-2012, 12:04 PM   #3
The system was not using salt so I did a manual regeneration and thats when it would not quit.
does this have any relationship to not using salt???Is the timer gone??
JIM
Old 05-03-2012, 01:43 AM   #4
Water Treatment
Rewards Points: 848
If the unit is plugged in to a known good outlet and the motor is Cold then yes the motor is toast..
Which Rainsoft is it?
Any way of a photo of the system?
If the motor is not working then it will A not start a cycle and B not work its way through the cycle and salt usage will be toast.
Akpsdvan is offline   Reply With Quote
Old 05-04-2012, 11:38 PM   #5
Can you manually advance the timer until it shuts off? There is probably a bypass valve you can open until you can repair it.
sanec1 is offline   Reply With Quote
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 09:44 PM
rumbling pipes and leaking pressure relief valve rogerwright Plumbing 21 04-14-2012 03:35 PM
(Water Heater MYSTERY) Hot water out from dead tank with cold water in it? Inayity Plumbing 6 07-14-2008 09:36 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
