-   -   rainsoft water softner (http://www.diychatroom.com/f7/rainsoft-water-softner-141838/)
jrenschen 04-28-2012 10:52 AM
The water keeps flowing. I turned off the power but to no avail. Whats wrong???
Thank you
joecaption 04-28-2012 10:58 AM
Timer stuck in back wash? Hard to say from here.
http://www.rainsoft.com/products/problem-solving.cfm
jrenschen 04-28-2012 11:04 AM
The system was not using salt so I did a manual regeneration and thats when it would not quit.
does this have any relationship to not using salt???Is the timer gone??
JIM
Akpsdvan 05-03-2012 12:43 AM
If the unit is plugged in to a known good outlet and the motor is Cold then yes the motor is toast..
Which Rainsoft is it?
Any way of a photo of the system?
If the motor is not working then it will A not start a cycle and B not work its way through the cycle and salt usage will be toast.
sanec1 05-04-2012 10:38 PM
Can you manually advance the timer until it shuts off? There is probably a bypass valve you can open until you can repair it.
