Rainsoft 14 Day Analog Timer - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-28-2012, 09:25 AM   #1
Rainsoft 14 day analog timer
I have a Rainsoft water system since 1999 a couple of months back the 14 day timer stopped working so I took it apart intending to check it out/repair myself. I found the larger motor turns but not moving the “timing wheels”. I finally got a new pin installed and went to reassemble ……..however; I’ve forgotten how it goes together!! I’m a “DA” I know…………does anyone have directions/diagram on how to put to getter?
Thanks….Carl r
carlrestivo is offline   Reply With Quote
Old 01-29-2012, 02:41 PM   #2
Water Treatment
Rewards Points: 902
A little more information on the Rainsoft.
They have used a few different valves over the years.
Most reticent is the Fleck 5000 valve or some times called the Proflo.
If it is that type then there is a manual on line that you could down load.
Akpsdvan is offline   Reply With Quote
Tags
rainsoft repair
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 10 03-25-2014 08:21 AM
GE SunSmart Timer 15312 Install DonSmith Electrical 4 01-16-2012 10:30 AM
GE Sunsmart Digital Timer Installation dtn311 Electrical 1 08-01-2011 01:16 AM
Mechanical timer wiring? Duane 70 Electrical 5 06-16-2010 08:57 PM
rainsoft timer jerrym General DIY Discussions 0 01-18-2010 12:02 PM
