Radiators - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-21-2005, 10:09 AM   #1
Radiators
I have a problem with two rad in my house... I have taken the rads off and flushed them out... drained gallons of water through the pipes/valves... I tried to balance the system.... started by turning off every other rad and left the two dodgy ones on... they seemed to heat alright... then slowly I opened the others in order to balance... I thought this was great... The following day when I turned on the heat these two rads failed to heat again...
Someone else suggested it could be water starvation... ie the pipes feeding these two rads are too small/smaller than the others.
I have had a few people look at it but it has baffled them all... I am about to call in a professional...
Just The One is offline   Reply With Quote
Old 09-22-2005, 01:00 AM   #2
Steam or Hot water?
K2eoj is offline   Reply With Quote
Old 09-22-2005, 12:49 PM   #3
Originally Posted by hammerslammer
Steam or Hot water?
Not entirely sure what you mean.... but it is hot water? Steam would indicate air surly?
help- vinyl tile under radiators. EASY WAY??????? brian fallon Flooring 3 07-08-2007 10:11 PM
Cold Radiators Raquelle HVAC 6 04-04-2007 02:20 PM
Hot Water Heating System Estimate Cost ? helpless handyman HVAC 45 12-26-2006 10:59 AM
Steam heat vs Hot water heat helpless handyman HVAC 5 10-03-2006 09:57 PM
Baseboard Hot Water radiators hotdiggitydog HVAC 2 04-25-2006 12:27 AM
