Radiator Won't Line Up With Pipes After Remodel. - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-08-2009, 06:43 PM   #1
Rewards Points: 49
Radiator won't line up with pipes after remodel.
I remodeled the bathroom, careful to keep the same floor level as before the demo, but of course the floor is a little higher now and the radiator I took out doesn't align with the heat pipes. What to do? They're a quarter of an inch off. Any kind of brackets or tubes to make up for this? Pleas help, it's already cold here!
jrdamien is offline   Reply With Quote
Old 10-09-2009, 09:29 AM   #2
Rewards Points: 346
There is often enough play in the pipes to make up a fraction of an inch. I did run into a similar problem may years ago with an antique gas appliance on a slab where tile was installed that raised the floor about 3/8". My solution was to grind the legs down enough to meet the gas line. Actually I seem to remember having to take a little more than 3/8" off the six legs and using small wedges to level it properly.
Rege
RegeSullivan is offline   Reply With Quote
Old 10-09-2009, 10:54 AM   #3
If you cannot get enough play in the piping to accomplish this, you may need to cut the legs of the radiator or carve a depression into the floor to make up the difference. Never seen any type flex fitting for a radiator.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Locate Return Recirculating Line Farmer Dean Plumbing 4 02-20-2009 06:47 AM
Bathroom remodel - lighting over shower / water line s4alex Electrical 15 10-10-2008 01:15 AM
GFI will not reset will line is hot soccerdude Electrical 15 09-07-2008 01:11 PM
sewer line back fall oakie14 Plumbing 2 09-04-2008 05:36 PM
