Radiator Line Under Slab - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-20-2012, 01:36 PM   #1
Radiator line under slab
I am putting down a new floor but before I do I want to bury a radiator line under the slab that is exposed from previous owner. I searched and read here that it should be buried under the slab, not in the slab. That was one question I had. Another question is should it be bent instead of using fittings under the slab. Someone told me this and will hire a plumber if this is the case. I planned on sweating the pipe myself and just get someone to bleed the line. Tring to do as much as I can on my own.
Joe442 is offline   Reply With Quote
Old 09-20-2012, 07:25 PM   #2
Rewards Points: 12,790
I'd use Pex not copper.
Old 09-20-2012, 07:28 PM   #3
DIY staff
Rewards Points: 7,174
Are you talking hot water heat?
If so consider PEX piping under the slab not copper---which ever you use under the slab is best for a transition line.
Old 09-20-2012, 08:43 PM   #4
Rewards Points: 582
use hydronic pex tubing for heating under slab..don't put any sweat joints underground...picture would help...
Pier on slab cer2012 Building & Construction 0 04-16-2012 09:52 PM
Extending Patio Slab and adding a cover Jeoroc24 Building & Construction 5 04-12-2011 12:16 PM
raised slab foundation tclark Building & Construction 6 01-07-2011 09:10 AM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
Concrete slab to foundation work tntgarv Building & Construction 3 02-28-2010 01:23 PM
