-   -   Radiator line under slab (http://www.diychatroom.com/f7/radiator-line-under-slab-157419/)
Joe442 09-20-2012 01:36 PM
I am putting down a new floor but before I do I want to bury a radiator line under the slab that is exposed from previous owner. I searched and read here that it should be buried under the slab, not in the slab. That was one question I had. Another question is should it be bent instead of using fittings under the slab. Someone told me this and will hire a plumber if this is the case. I planned on sweating the pipe myself and just get someone to bleed the line. Tring to do as much as I can on my own.
joecaption 09-20-2012 07:25 PM
I'd use Pex not copper.
oh'mike 09-20-2012 07:28 PM
Are you talking hot water heat?
If so consider PEX piping under the slab not copper---which ever you use under the slab is best for a transition line.
ben's plumbing 09-20-2012 08:43 PM
use hydronic pex tubing for heating under slab..don't put any sweat joints underground...picture would help...:yes:
