Radiator Boiler Problem - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-11-2009, 12:58 AM   #1
My boiler automatically shuts off when the water gets to low. At first it was happening every couple of days. Then it went to every Day. Now it last about 7 -10 hours before I have to fill it up. I checked the radiators no significant leaks that I can see. Any ideas?
JmalikS is offline   Reply With Quote
Old 01-11-2009, 08:07 AM   #2
<~~ not a plumber
could be your boiler fill valve. check the presure on the boiler, if its less than what your fill is set for, ( 12 pounds +/-) you might need to replace it. Most of them are put on with unions so its an easy swap.
II Weeks is offline   Reply With Quote
Old 01-11-2009, 08:46 AM   #3
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,624
Ayuh,...
With a closed Boiler system,....
Any Leaks are Very Significant....
Is this a Steam system, or Hotwater,..??
Bondo is online now   Reply With Quote
Old 01-12-2009, 10:09 AM   #4
Checked the radiators again. There are two radiators that when i put my finger under the part where the radiator connects to the pipe going through the floor, there is moisture. About the equivalent of a drop or two of water. Is this enough to empty the system to the point it automatically shuts off?
This is a closed Steam System
Phone Jack Hookup Problem kennykenny Electrical 21 04-09-2017 10:36 AM
Neutral problem, not sure what to do now BataviaJim Electrical 37 01-03-2009 11:00 AM
Electrical "arcing" problem? morden5b Electrical 17 12-17-2008 06:10 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 01:51 PM
