Radiator - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-21-2009, 11:24 AM   #1
Radiator
Our house is heated by radiators. We hsve hot water but our house is not heating what could be wrong?
simba12 is offline   Reply With Quote
Old 03-21-2009, 01:31 PM   #2
Whatamess
Is the circulating pumps working?
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 03-21-2009, 04:26 PM   #3
radiator
Yes, the curulating pump is working.
Old 03-21-2009, 06:31 PM   #4
HVAC / Plumbing
air in the system ?? stopped up radiator / pipes ?? pump cavitating ??
kenmac is offline   Reply With Quote
Old 03-24-2009, 10:23 PM   #5
I do not know why but the heat is on.
Old 03-24-2009, 11:18 PM   #6
Rewards Points: 156
this might be a stupid question
This might be a stupid question but are your radiators oil?
jayp is offline   Reply With Quote
Old 03-26-2009, 09:52 PM   #7
hot water out again
This is driving me crazy. The heat in the house is out again. The hot water is on and when we turn on the hot water it's so much more hotter than before and there seems to be more pressure to it. I do not know if I should call some one to look at it.
Old 03-26-2009, 09:53 PM   #8
What type of boiler do you have?
Is the hot water part of the boiler?
What method of fuel?
Old 03-26-2009, 09:55 PM   #9
radiator
the radiator is water not oil.
Old 03-26-2009, 10:23 PM   #10
Have you tried blkeeding the radiators? Do you have an automatic fill valve on the boiler? Are the pipes above the circ pumps getting hot?
hayewe farm is offline   Reply With Quote
Old 03-26-2009, 10:42 PM   #11
HVAC / Plumbing
If the pump ( not the motor) is broken ( not moving water) or, Air in the system ...you will have to bleed
No/little heat on 3rd floor apt collar Plumbing 3 12-06-2008 08:17 AM
Radiator Question mismos00 HVAC 17 11-02-2008 03:55 PM
HELP! poor daugthers radiator question fauer Automotive Repairs 6 03-16-2008 05:25 AM
Hot Water System -- Cold Radiator formarley HVAC 4 03-04-2008 08:09 AM
downsizing radiator aak3 Plumbing 1 02-14-2008 05:14 PM
