Radiant Heating In My Spa - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-03-2012, 11:29 AM   #1
Radiant Heating in my Spa
I'm building a spa room in a separate structure from my home. My contractor has already run the radiant floor tubing under the sub floor and the insulator has installed the reflective foil. I'm trying to decide which is the best choice for the boiller. I am planning on using the same boiler to heat the water for the shower, Lav fixtures, tub and also run the radiant floor.
I was planning on using a Munchkin MC-50 Contender series boiler and contender series 50 gallon tank. The radiant floor area is approximately 500 sqft. The shower has a pour head, rain head, (2) body sprays, and a hand held. There are (3) Lav Faucets and a 60 gallon tub.
Are there any concerns I should be considering with this configuration? Has anyone done a project like this? I 've been trying to get help from Munchkin on all the equipment that I will need for this project and no one seems to be able to answer the questions. Thanks in advance for any help you can provide.
Mountainspa is offline   Reply With Quote
Old 03-03-2012, 03:37 PM   #2
Rewards Points: 91
Where are you located?
George6488 is offline   Reply With Quote
Old 03-03-2012, 07:50 PM   #3
I'm in Big Bear, Ca
Installing radiant heating in a basement and general basement questions... CarlsonRower General DIY Discussions 6 12-09-2011 12:32 AM
Radiant floor heating system has major leak, need to replace hoekzebs HVAC 3 03-29-2011 03:18 PM
Considering Radiant Heating acerunner Remodeling 4 07-03-2010 02:17 AM
Radiant floor heating questions secutanudu HVAC 35 03-08-2010 01:04 PM
using forced air for radiant heating djsmith9 HVAC 22 10-30-2008 09:50 AM
