Radiant Heat Questions - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-04-2010, 03:49 PM   #1
Rewards Points: 252
radiant heat questions
Hi all,
I am doing a little renovating in the house and meeting with a plumber to discuss my heating options in a few days - before I did so wanted to pick some brains on this site...
I have a hot water boiler and one of the zones is currently feeding the master bathroom and master bedroom. The master bedroom has baseboard heat and the master bath has toekick heaters (which I HATE!!). So when I re-do the bathroom I want to install hydronic radiant. Everything I know about radiant tells me I'm going to have to run a seperate zone to the bathroom - no big deal but we'll have to break a bunch of sheetrock and drill through a boatload of joists to do so. Is there anything out there that would allow me to use the exiting lines and run radiant in the bathroom and still keep the baseboards? I wouldn't be opposed to changing the baseboard heat in the master bedroom, is there anything that I can replace the baseboards with that would allow me to use the existing copper lines up to that side of the house??
thank you!
mazzonetv is offline   Reply With Quote
Covering Radiant Heat ceilings. Hockeynews Remodeling 3 04-10-2009 08:23 AM
Radiant Heat and Tile Texasguy HVAC 5 04-07-2009 10:14 AM
Replace forced air heat vent with radiant floor malfunction HVAC 9 02-05-2009 12:01 PM
Laminate in Basement over Hydronic Radiant Heat art2670 Flooring 3 10-12-2007 10:17 PM
Radiant Heat Flooring As Only Heat Source? digthisbigcrux Building & Construction 2 03-10-2007 11:33 AM
