Radiant CounterTop - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-13-2010, 03:30 PM   #1
Radiant CounterTop
My project is to heat a cast concrete counter top. I want to thermostatically control the temperature. I would like to circulate through my Hot Water boiler. I want to achieve this result as inexpensively as possible. I plan to use 1/4" O.D. PEX within the cast. If I tie in the ability to back flush the system I am hoping that I can avoid the heat exchanging expense. I am hoping to be able to tap into the DHW supply with a small inline pump or valve thermostatically controlled and return directly to boiler supply line. Does this sound like a reasonable idea? Your help is appreciated.
home_slice is offline   Reply With Quote
Old 10-13-2010, 09:36 PM   #2
Licensed Master Plumber
Just the one question. Why?
Always ask to see your contractors license!
NHMaster is offline   Reply With Quote
Old 10-13-2010, 09:38 PM   #3
Why not ?
I want to do the same thing
Counter top gets cold in the winter
Old 10-14-2010, 08:07 AM   #4
Why have a radiant heated bar-top?
The countertop I am referring to is actually a bar-top that is elevated along one edge of a kitchen island. What do people do when approaching a bar-top? Often they will lean on it with one arm or when sitting at a bar rest their arms on it. A warm surface is inviting. This surface will radiate heat into the house during the winter. If making bread the dough will rise nicely. The first reason is enough for me.
Old 10-14-2010, 02:20 PM   #5
I would look into the electric radiant heat cable used under ceramic floor tile. It would be a whole lot less complex than a pump and a valve and back-flushing. And less complex usually means less cost.
Pistol Pete is offline   Reply With Quote
Old 10-15-2010, 06:49 AM   #6
Electric Radiant Heating
warmsmeallup's Avatar
Rewards Points: 150
How many square feet of coverage is there in this top?
www.comfortradiant.net
warmsmeallup is offline   Reply With Quote
The Following User Says Thank You to warmsmeallup For This Useful Post:
home_slice (10-18-2010)
Old 10-18-2010, 02:09 PM   #7
The top is only about 9-10 sq/ft surface. It has a weird amoeba shape, no straight edges and 2" Thick. Does anybody know if they make an electric coil or tape for this application?
Old 10-18-2010, 02:48 PM   #8
Chicago, IL
Michael Thomas's Avatar
Have you considered installing a hanging fixture or two and installing low wattage IR bulbs? Whole lot less work....
BTW, I've got the opposite problem... my wife keeps asking me to find a way to refrigerate a portion of one of our counter tops, so that is will be easier to roll out pastry .
I'm considering installing a inlaid section of marble above a under-counter refrigerator with the top removed, when not in use as a "refrigerated" counter top an insulated cutting board would sit on top of the marble. Whole lot more work than just cooling a piece of marble in the refrigerator...
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 10-18-2010, 02:54 PM   #9
Rewards Points: 150
You could use a line voltage cable system with an in-slab sensor for the thermostat. That would allow you to shape the system to the top. You would have to set the top in a mortar. All electric cable heating elements of this design need to be in a mortar as a heat sink.
You could also use a low voltage system but it would cost more. You would get a much better warranty (25 years on the element compared to 10 years for line voltage) and it is a much more rugged element to work with but I think for this size system, the line voltage would be a simpler install. The low voltage system would need space for a 7" square box for the transformer in a location within 20 linear feet of the top.
The cost difference is nominal. Maybe $100. more for the low voltage system. In both cases you must use all of the element that comes on the roll so there is a calculation we could help you with for element spacing. There is no cutting or overlapping of the element.
Old 10-18-2010, 03:00 PM   #10
jlhaslip's Avatar
Rewards Points: 2,748
There are heating elements that get thinsetted down under tiles that might work if you have access to the underside of the concrete countertop.
[edit]
didn't read the above reply. Likely the same thing.
[/edit]
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Tags
plumbing , radiant
How to install countertop over washer and dryer R V Dunai Remodeling 13 08-21-2011 02:07 PM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 08:22 PM
receptable inside cabinet DIYGST Electrical 8 01-29-2010 07:05 PM
steam v. hot water, radiant sub-system Lor HVAC 1 06-11-2009 03:58 PM
countertop installation - stove/oven issue diycarguy Building & Construction 12 05-04-2009 01:08 PM
