R & M Water Group, S N 78950 - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-28-2013, 06:20 PM   #1
We recently purchased a home that had a water softener made by R & M Water Group, Serial Number 78950. It has a slow small leak where the valves attach to the top of the black round cylinder, not the salt bin. I believe that there is an "O ring" where they join and it appears to be leaking. How much of a problem is it to replace this "O ring" and where can I obtain the correct replacement? You help concerning this matter will certainly be appreciated, thanks.
buckshot123 is offline   Reply With Quote
Old 01-28-2013, 06:24 PM   #2
Rewards Points: 13,444
If it's just an o ring any hardware store, plumbing supply, box store will have them.
Just bring the old one with you.
buckshot123 (01-28-2013)
Old 01-28-2013, 09:14 PM   #3
Water Treatment
Rewards Points: 850
It could be the plastic ring that holds the rubber o ring in place.
Does your unit look any thing like this?
http://www.pentairwatertreatment.com...et%2040729.pdf
This is a Fleck 2510 valve.
If it is the plastic ring then the hardware store will NOT have it.
Akpsdvan is offline   Reply With Quote
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
water borehole question joeuser General DIY Discussions 2 04-18-2010 10:33 PM
How Do I Properly Shock Chlorinate a Water Softner classicflytyer Plumbing 5 07-14-2009 12:15 AM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 09:31 PM
