Old 03-03-2013, 12:57 PM   #1
Bill Kearney
quiet drain noise
Ok, so I know cast iron does a better job of reducing drain noise for vertical drops. But what about the horizontal sections? We've got a master bath that's going to be over a large family room. I don't want to be hearing the tub, toilet and shower downstairs. There will be a number of 5 to 7' stretches of drain to get from the various fixtures to the vertical pipe. Should these also be in cast iron?
Sure, there's an added cost, but I *really* do not want the noise.
wkearney99 is offline   Reply With Quote
Old 03-03-2013, 01:09 PM   #2
Persona Non Grata
VIPlumber's Avatar
quiet drain noise
I've used Schedule 80 ABS in these situations. Smaller id, same od, thicker wall which helps to lessen the water noises.
VIPlumber is offline   Reply With Quote
Old 03-03-2013, 01:22 PM   #3
quiet drain noise
Adding some insulation and using 5/8 sheetrock on that wall will also help.
Old 03-03-2013, 02:09 PM   #4
call me E
TheEplumber's Avatar
quiet drain noise
Insulation is good. Also consider sch 40 or 80 pipe instead of foam core DWV pipe. Cast is pretty spendy and heavy- I'd almost consider copper instead....
There are commercial grade pipe insulation systems available. Perhaps you can find a pipe wrap company in your area and cut a deal with him.
Connecting shower drain to toilet drain Liv Plumbing 10 04-17-2013 11:53 PM
Avoiding a frozen paver drain BrandonC_1972 Plumbing 2 04-28-2012 10:11 AM
Scupper drain installation advice needed miamicuse Roofing 9 02-11-2012 10:59 AM
Washing machine drain line noise MikeKy55 Plumbing 2 12-03-2009 09:19 PM
relocating washer drain idodishez Plumbing 7 04-21-2009 09:36 PM
