-   -   quiet drain noise (http://www.diychatroom.com/f7/quiet-drain-noise-173486/)
wkearney99 03-03-2013 12:57 PM
quiet drain noise
Ok, so I know cast iron does a better job of reducing drain noise for vertical drops. But what about the horizontal sections? We've got a master bath that's going to be over a large family room. I don't want to be hearing the tub, toilet and shower downstairs. There will be a number of 5 to 7' stretches of drain to get from the various fixtures to the vertical pipe. Should these also be in cast iron?
Sure, there's an added cost, but I *really* do not want the noise.
VIPlumber 03-03-2013 01:09 PM
I've used Schedule 80 ABS in these situations. Smaller id, same od, thicker wall which helps to lessen the water noises.
joecaption 03-03-2013 01:22 PM
Adding some insulation and using 5/8 sheetrock on that wall will also help.
TheEplumber 03-03-2013 02:09 PM
Insulation is good. Also consider sch 40 or 80 pipe instead of foam core DWV pipe. Cast is pretty spendy and heavy- I'd almost consider copper instead....
There are commercial grade pipe insulation systems available. Perhaps you can find a pipe wrap company in your area and cut a deal with him.
