Quick Question: Shower Drain Gaskets - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-07-2012, 08:27 AM   #1
Quick question: shower drain gaskets
I'm putting a new fibreglass shower base in and have a quick question about my shower drain gaskets.
I bought a pretty standard 2 piece drain. The only question I have is about the gaskets. The drain has one rubber gasket and one anti-friction gasket. Where exactly do these 2 gaskets go?
From what I've read, I use the rubber gasket below the shower, but where does the friction gasket go? I'm assuming below the shower pan, but does it go between the pan and the rubber gasket, or below the rubber gasket? Or do I need it at all? I have complete access under the shower and I'll be connecting new pipes and a P trap after the shower is installed.
Sorry, there weren't any instructions with the drain.
Thanks for any help.
MANGINA is offline   Reply With Quote
Old 09-07-2012, 08:32 AM   #2
Rewards Points: 13,446
Slide the rubber gaskit over the treads on the drain and drop it in.
The friction washer goes on the bottom under the show so as your tightning up the nut it does not drag on the bottom of the shower as it's turning.
Old 09-07-2012, 08:36 AM   #3
Awesome. Thanks!
Old 09-07-2012, 09:04 AM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 542
silicone or putty on the top, rubber and friction ring on the bottom.
Old 09-07-2012, 09:10 AM   #5
Doing it myself
Alan's Avatar
Rewards Points: 2,086
No.
Both gaskets go below......
Order :
Shower Drain ---> Putty -----> Shower base ----- > Rubber gasket ----> Friction gasket -----> Brass nut
Journeyman Plumber
Old 09-07-2012, 10:16 AM   #6
Originally Posted by Alan View Post
No.
Order :
Do you think putty is better than silicone? I just want to know what to pick up.
Old 09-07-2012, 10:19 AM   #7
both go underneath, rubber against the bottom of the shower base and
the friction washer against the nut.
the friction ring is to keep the nut from pushing the rubber gasket out as
you tighten the nut.
Old 09-07-2012, 09:22 PM   #8
Doing it myself
Alan's Avatar
Yes I do. If you ever have to reset the drain, and you have to clean off silicone, you will jump off a building.
Putty is the way to go.
Journeyman Plumber
Old 09-08-2012, 07:32 PM   #9
Rewards Points: 582
joe ...putty on flange slide through shower....under unit rubber gasket to bottom of shower paper gasket to rubber... locking nut.....in that order...ben sr ..
Need help setting shower drain in existing slab drain hole! deedeedeeIY Kitchen & Bath Remodeling 9 05-11-2012 09:39 AM
Shower to Tub; using the original drain? recmhb Plumbing 0 08-01-2011 10:07 AM
Sewage smell from shower drain, trap has water, vent was snaked and was clear clearasmud Plumbing 1 04-24-2011 06:28 AM
shower drain screen gaskets clr Plumbing 0 04-17-2011 08:30 AM
AAV or Studor Vent Needed for this Tub and Shower Drain? BillyDIY Plumbing 1 12-16-2008 11:11 PM
