Quick Question Re: Bathtub Roof Exhaust . . . - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-16-2012, 11:04 AM   #1
dazed 'n confused
watts up?'s Avatar
Quick question re: bathtub roof exhaust . . .
We have the 2" PVC pipe installed for our new baththub's vent exhaust and it sticks up through the roof, as planned. My question is:
Should there be some kind of little "hood" or "grill" over the top of this PVC roof pipe to keep leaves, mice etc. from getting into the pipe and clogging it . . . or is this just not necessary? Thanks.
wu
watts up? is offline   Reply With Quote
Old 01-16-2012, 11:08 AM   #2
Rewards Points: 3,130
Normally not necessary. Does need to be at least 12 inches high (so it doesn't get covered with snow). If you're really concerned about it, you can pick up a push-on cap at most RV dealers.
The Following User Says Thank You to md2lgyk For This Useful Post:
watts up? (01-16-2012)
Old 01-16-2012, 11:14 AM   #3
dazed 'n confused
watts up?'s Avatar
Good good. Thanks man.
wu
Old 01-16-2012, 11:21 AM   #4
Rewards Points: 13,274
I've never once seen any form of cap on a sewer vent. Not needed.
Old 01-16-2012, 11:59 AM   #5
Rewards Points: 150
I think he meant it for his exhaust fan in the bathroom, and if that is the case, out of curiousity, what stops the exhaust air from condensating and running back into the fan.
psilva8 is offline   Reply With Quote
Old 01-16-2012, 12:43 PM   #6
Originally Posted by psilva8 View Post
I think he meant it for his exhaust fan in the bathroom, and if that is the case, out of curiousity, what stops the exhaust are from condensating and running back into the fan.
Read the original post again. He's talking about the vent for his bathtub, not an exhaust fan.
Old 01-16-2012, 12:47 PM   #7
MarginallyQualified
Rewards Points: 2,464
Actually the OP is rather vague.
He describes a DWV vent but also asks about a bathtub exhaust.
I suspect he MEANS the DWV... but I'm not certain he does.
[quote=watts up?;824398]
We have the 2" PVC pipe installed (for our new baththub's vent exhaust )
and it sticks up through the roof...
NEED URGENT ADVICE: roof sheeting question diybrad Roofing/Siding 2 11-15-2011 02:02 PM
Carport Lean to Roof Question.. jgcable Building & Construction 31 04-29-2011 06:12 PM
Roof Rafter question Rookie3550 Building & Construction 3 07-29-2010 02:30 PM
Another roof ventilation question Jim F Roofing/Siding 9 05-13-2010 08:51 PM
steel roof question kindrngentlr13 Roofing/Siding 5 06-18-2008 12:29 PM
