Quick Plumbing Question - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-31-2013, 06:15 PM   #1
Rewards Points: 150
Quick plumbing question
When running your pipes and making a mid-run 90 turn from vertical to horizontal, should you do this with a 90 or with a T and put an 8" capped piece sticking up, to dampen any possible water hammer? Or should you only do this at the fixtures?
SquishyBall is offline   Reply With Quote
Old 05-31-2013, 06:53 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 922
Water hammer arrestors or air chambers should be as close to the valve as possible. IMO- you gain nothing install air chambers in random spots
Old 05-31-2013, 07:45 PM   #3
Master Plumber
Javiles's Avatar
Rewards Points: 996
IPC only at mechanical valves no longer required at fixture groups
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 05-31-2013, 08:18 PM   #4
Rewards Points: 150
Thank you both! Very helpful, as always.
New here! Quick question. tmichelsons Building & Construction 5 06-15-2011 12:18 AM
High rise Plumbing question roach_779 Off Topic 8 01-17-2011 08:36 PM
Utility Sink Plumbing Question justinL Plumbing 2 08-16-2010 08:10 PM
Plumbing Job Question Bigd3129 Plumbing 13 08-09-2010 12:56 AM
Question re: plumbing air lines in my shop Termite Plumbing 12 02-14-2010 10:37 PM
