Old 12-13-2007, 11:22 AM   #1
Quick connect sink?
Has anyone here heard of a quick connect sink? A coworker needed a new sink. So the plumber told him that there wasnt enough lip on the front of the cabnet to install the proper anchors. I"ve installed a new sink before and ran into the same problem I just used two clamps on each side and two in the back. It turned out ok . Hasent leaked yet a year later. The reason Im asking is that they told him that these sinks are 400$ Any thoughts?
Please help....................................Rick...... ...............................
rick32 is offline   Reply With Quote
Old 12-13-2007, 12:27 PM   #2
Quick connect sink?
I have not heard about these sinks but silicone is a lot cheaper than that. Sounds like someone is trying to make a fast buck.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 12-13-2007, 02:07 PM   #3
Quick connect sink?
I call hog wash! I'm assuming it's a kitchen sink? Like majak said, silicone is your friend. Get the clamps on where you can and caulk the rest. Heck, even if you needed to re-caulk it every year it would save a lot of money.
perpetual98 is offline   Reply With Quote
Did I ruin toilet/vent after installing sink??? nibeck Plumbing 4 09-06-2012 08:07 AM
Single Sink To Double Sink 39centstamp Plumbing 4 06-24-2007 11:27 AM
Fixing a sink - paint removed from the sink deb14905 Painting 2 04-19-2007 12:26 AM
installing vessel sink drain?! (HELP!) tara Plumbing 2 11-10-2006 01:17 AM
Drain connection for basement utility sink chickenboo Plumbing 5 09-11-2006 03:30 PM
