Quick Connect Natural Gas Splitter - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-27-2013, 01:32 PM   #1
Quick connect natural gas splitter
Hey all I have a natural gas hookup on the patio. Was wondering if there was some kind of quick connect splitter I could hook up so i can have my gas firepit and BBQ going at the same time
Bubski27 is offline   Reply With Quote
Old 04-27-2013, 07:50 PM   #2
DIY staff
Rewards Points: 7,174
I moved this to plumbing for you---
You need to post a picture of what you have----typicality a T- is used and two seperate quick connections are used----
The real question is this---will that pipe supply enough gas to run both units at the same time---
Get the BTU ratings from both and the pipe size and come back---
Old 04-27-2013, 08:25 PM   #3
Rewards Points: 582
you go mikey.....ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
oh'mike (04-27-2013)
Old 04-28-2013, 07:50 AM   #4
Rewards Points: 2,516
My guess is 45K BTU grill and 80K BTU firepit on a 1/2 line. Thats a total of 125K BTU
This table is in the Natl Fuel Gas Code. 10 feet of 1/2 black pipe can deliver 131 cubic feet of gas per hour. So thats about 132K BTU per hour. Since 1 cub foot of natural gas is equal to 1015 BTU.
So hopefully your run of 1/2 is less than 10 feet to have both function properly if going at the same time.
If you do need to use a Tee to split anything, note that a Tee is equivalent to 3.10 feet of straight pipe.
hammerlane is offline   Reply With Quote
Connect UF-B cable totransfer switch / Inlet box Vkazman Electrical 8 03-17-2013 02:55 PM
How to wire a 30A 250v plug and connect it to a well pump control box diyorgobroke Electrical 3 05-21-2012 04:08 PM
Combine 7' garage doors into one 16+ ft door - connect brick lintels Irestone Concrete, Stone & Masonry 12 03-22-2012 03:51 PM
Has anyone used the Watts Quick Connect Fittings? luweee Plumbing 8 02-28-2011 08:02 PM
Quick connect sink? rick32 Plumbing 2 12-13-2007 01:07 PM
