Question On Venting - Plumbing - DIY Home Improvement | DIYChatroom
Old 09-12-2012, 03:06 PM   #1
Rewards Points: 89
Question on Venting
I'm pretty sure I am going to have to hurt someone! I had some plumbing done for my bathroom remodel since I have been working to much and needed to get it completed.
He finished yesterday and I had time to go review the work today. Correct me if I am wrong but unless something changed recently...Terminating the vent pipe in the crawl space is no bueno right?
Also, would using an AAV off a dual sink and putting it in the wall cavity also be incorrect?
REXAMUS is offline   Reply With Quote
Old 09-12-2012, 03:40 PM   #2
Rewards Points: 89
Some pictures...
Old 09-12-2012, 07:20 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 554
That doesn't look like a vent. Is that a san tee behind it? That would be the vent and the 90 appears to be a toilet bend- ready for a flange at the floor line. I'm guessing 3" pipe..
As for the AAV- I very seldom use them and I don't put them in the wall without a louvered access panel.
What has the plumbing inspector said- there is a permit right?
Old 09-12-2012, 08:07 PM   #4
Where I live, AAV cannot be enclosed behind a wall at all.
Also, I am not a pro but I am pretty sure it is not a generally accepted practice to mount waste pipes on a stack of left over 2x4.
Hope you did not pay the guy yet? I would ask him to pull a permit and fix and bring everything up to code.
ps. I haven't dealt too much with pex, but shouldn't those stub outs be supported by a blocking of some sort as pex tubing does not offer structural rigidity, unlike a copper tubing?
Last edited by allthumbsdiy; 09-12-2012 at 08:10 PM. Reason: added a statement about pex stubouts
allthumbsdiy is offline   Reply With Quote
Old 09-12-2012, 08:51 PM   #5
Doing it myself
Alan's Avatar
Rewards Points: 2,086
While I would never do something like that, the code only says the piping has to be supported, not how it must be supported.
That looks like a friggin mess. AAV should be accessible if it MUST be used.
If that is a 90 left for a closet flange, I would think it would be temporarily capped or plugged...
Journeyman Plumber
Old 09-12-2012, 09:11 PM   #6
Rewards Points: 636
wow that is not a legal a a v since it has a spring in it and here you are allowed to put in wall as long as it is accessible and breathable here is he i.r.c. on aav
http://publicecodes.cyberregs.com/ic...?bu2=undefined
also pex should be supported at sub outs
and no you can not just have open vent in crawl space
was this the plumber who name you found in a restroom stall
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 09-12-2012, 09:16 PM   #7
Rewards Points: 47
First of all , a aav installed below the flood level of a basin is definitively
a no-no. This guy doesn't know what he is doing. The work in the other
picture looks amateurish too (IMHO). The top of the closet el isn't parallel
with the floor. Fit up might be an issue. Only takes a little time and some
knowledge to do the job right. I'd part ways with this guy.
LeakyMike is offline   Reply With Quote
Old 09-12-2012, 09:47 PM   #8
Water stub outs should look like this,
and AAVs must be accessible, usually behind a grill or access panel.
One question. What exactly is being vented in your crawlspace?
VIPlumber is offline   Reply With Quote
Old 09-12-2012, 10:07 PM   #9
Master Plumber
Javiles's Avatar
Rewards Points: 994
Wow you need to get someone that knows whats hes doing, lots of mistakes, along with multiple code violations poor workmanship. get rid of this clown!
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 11-04-2012, 04:43 PM   #10
Rewards Points: 89
I hate I forgot about this thread. I had completed the rest of the bathroom myself because I hate trusting others to do work. If it's going to be messed up I'd rather blame myself and still have money in my pocket.
Anywho..I managed to get some of the money back. Unfortunately the company had great reviews everywhere I looked but I guess I could have done a better job on looking at their past jobs.
I think the main problem is that a lot of people pay people like this to do things but don't know if it's right or wrong. I semi have a clue how things SHOULD be done but that doesn't mean I want to bother with doing it.
I've been busy the last couple of weeks but I'm going to get all the pex fixed this week and put copper stubouts at the vanity and shower. I am also going to finish removing all the AAVs and running the vent pipes out the roof. Thanks for all the input!!!
Old 11-05-2012, 09:14 AM   #11
Doing it myself
Alan's Avatar
a no-no.
Depends on what code you're using. Our says minimum of 4" above the trap outlet.
Journeyman Plumber
Another Venting Question rpratt84 Roofing/Siding 3 07-12-2012 03:17 PM
Dryer Venting Question jabond Appliances 2 06-21-2012 03:08 PM
Venting question Sammy 2 Plumbing 2 02-14-2011 08:57 PM
Question about dryer venting jimithing78 HVAC 10 08-26-2008 11:37 AM
Rheem classic 90 plus venting question jjconst07 HVAC 2 07-04-2008 05:14 PM
