Question - Tub Drain Size - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-02-2010, 02:16 PM   #1
I am planning out my bathroom remodel - trying to make a materials list.
My current 20 year old cast Iron tub is connected to the stack with a 1.5 inch ABS pipe. I will need to replace this obviously and read somewhere that new codes require 2 inch drains on tubs.
In looking at the tub shoe sets at HD and Rona I only saw 1.5 inch sets.
Can someone explain what the standard size is now and whether I need to connect the 1.5 inch tub show to a 2 inch ABS darin pipe.
I believe I will need to install a new Y in the 4 inch stack so I want to make sure I have thought this through before it comes down to "crunch time"
Thanks in advance.
D
dmanmtl is offline   Reply With Quote
Old 01-02-2010, 02:48 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
I'm not a licensed plumber, just a long-time DIYer, but I believe that 1.5" is fine for a tub, but you need 2" for a shower. Check with your Building Inspection Department for local code.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 01-07-2010, 02:11 PM   #3
Rewards Points: 150
i am a lic. plumber and this is true
rudolph58 is offline   Reply With Quote
Using sharkbite to fit leak in pipe...pipe hole size question. RyanD Plumbing 4 08-14-2009 07:17 PM
Circuit Size Question techinstructor Electrical 12 06-28-2009 09:24 AM
A lesson learned - don't make my mistake and a pvc drain question edwood79 Plumbing 0 11-20-2008 11:09 PM
It's true. Size matters. - Carpeting Question kcrossley2 Flooring 4 11-19-2008 12:32 PM
Condensor drain Captflx HVAC 6 08-17-2008 11:19 AM
