-   -   Question of replacing a tub with a shower unit (http://www.diychatroom.com/f7/question-replacing-tub-shower-unit-124187/)
noviceshock 11-21-2011 12:43 PM
I was wondering as I look at most or if not all shower units the drain is in the middle of the unit. However the Tub I am replacing has the drain somewhere between 6-10 inc from the wall. This appears not to be enough room for a center drain shower. Will I have to move the drain or is there another way to put in a shower unit?
broox 11-21-2011 04:12 PM
You will have to move the drain
dsconstructs 11-21-2011 06:41 PM
Depending on the type of shower pan you are looking for. There are some "retrofit" pans, made for just this sort of thing.
http://www.faucetdirect.com/swanston...-drain/p303538
md2lgyk 11-22-2011 07:50 AM
If it is a typical tub/shower installation, it is probably a 1-1/2" drain. Shower units require a 2" drain, so you'll have to change it anyway. When you do, put it where you want it.
dsconstructs 11-22-2011 08:28 AM
True about the drain size, but easier to adapt to a 2" drain in existing location rather than moving it.
I've used those retrofit pans in situations where it saved a lot of framing work due to joist/girder locations for example.
The retrofit pans are also available in cultured marble products as well, but cost a bit more than the veriteks and other brands.
