[SOLVED] Question removing bathroom pipe from wall
I have a question on removing the drain extension pipe from the wall. I want to replace the pipe with a shorter one so it can fit ikea cabinets. See pictures.
Basically I cannot remove this piece after removing the nut that held it in place. I would think it would remove after the nut(can be seen at the bottom of pic3) but I see that there is another white-nut thing in the back that i can try to use a wrench to unscrew it if it is clamping the pipe down but I dont want it to loosen it if it going to loosen improperly the other end of the pipe in the dry wall.
Does anyone know how I should proceed? I dont want to apply too much pressure breaking something behind the drywall if I am not supposed to or jump to conclusions without hearing from some others with more experience.
Guys, look real close at that trap where it goes into the adaptor, looks like it was threaded in, not just a cheap thin slide in.
Why else would there be a brass insert in the PVC?
it's a brass desanko threaded onto a piece of galvanized. the trap is just stuck in it. sometimes a twist on the trap arm will loosen it or you may have to use a thin screwdriver like someone suggested.
It's a brass trap adapter screwed on to a galvanized nipple. Typical of older homes with galvanized plumbing. You're lucky if the trap isn't soldered in.
I was able to remove it. I added some WD-40 and let it settle for a few minutes. A simple turn as suggested did the trick. Good thing it wasnt soldered or glued on.
I found some pretty bad build up going on inside. I removed it. Seems like some sand/drywall powder buildup from some previous work around the house (from washing hand, etc). Good thing I was able to get this cleared up while I am redoing the pipes.
What do you mean by wanting to fit in a Ikea cabinet? They are standard sizing, just like any other cabinet. Most people will just cut a rectangle from the back, so they do not have to do any plumbing changes.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.5K members
Since 2003
