-   -   Question removing bathroom pipe from wall (http://www.diychatroom.com/f7/question-removing-bathroom-pipe-wall-160688/)
caicom98 10-21-2012 03:27 AM
[SOLVED] Question removing bathroom pipe from wall
3 Attachment(s)
I have a question on removing the drain extension pipe from the wall. I want to replace the pipe with a shorter one so it can fit ikea cabinets. See pictures.
Basically I cannot remove this piece after removing the nut that held it in place. I would think it would remove after the nut(can be seen at the bottom of pic3) but I see that there is another white-nut thing in the back that i can try to use a wrench to unscrew it if it is clamping the pipe down but I dont want it to loosen it if it going to loosen improperly the other end of the pipe in the dry wall.
Does anyone know how I should proceed? I dont want to apply too much pressure breaking something behind the drywall if I am not supposed to or jump to conclusions without hearing from some others with more experience.
Thanks any ideas would be great!
oh'mike 10-21-2012 06:58 AM
That trap arm has gotten stuck with corrosion---I usually crush the tube a bit to free it up.
Use a very thin screwdriver---drive it in between the tube and the trap adapter (pipe in the wall)
the trap arm is thin --it'll give up before the trap adaper is damaged.
ben's plumbing 10-21-2012 07:47 AM
some of the plumbers in my area soldered them in also ....making it tough to replace it...ben sr
joecaption 10-21-2012 08:27 AM
Guys, look real close at that trap where it goes into the adaptor, looks like it was threaded in, not just a cheap thin slide in.
Why else would there be a brass insert in the PVC?
oh'mike 10-21-2012 09:51 AM
Joe---the pipe looks like painted steel to me (ror brass) you can see the retaining nut is paint covered---
joecaption 10-21-2012 09:57 AM
http://www.bing.com/images/search?q=...2993C4&first=1
Looks like one of these to me.
The brass ring was to keep the fitting from cracking like often happens with a soild PVC adaptor.
DannyT 10-21-2012 01:29 PM
it's a brass desanko threaded onto a piece of galvanized. the trap is just stuck in it. sometimes a twist on the trap arm will loosen it or you may have to use a thin screwdriver like someone suggested.
http://www.amazon.com/gp/offer-listi...I&linkCode=asm
caicom98 10-21-2012 02:30 PM
Ahh yes. It does look something like this http://www.abwplastics.co.uk/ekmps/s...aded-719-p.jpg
I will give it a try to wiggle it out. Then I will try to wrench out this adapter if it appears to be stuck. I will fill you guys in if I have success
Alan 10-21-2012 02:44 PM
It's a brass trap adapter screwed on to a galvanized nipple. Typical of older homes with galvanized plumbing. You're lucky if the trap isn't soldered in.
caicom98 10-21-2012 03:29 PM
I was able to remove it. I added some WD-40 and let it settle for a few minutes. A simple turn as suggested did the trick. Good thing it wasnt soldered or glued on.
I found some pretty bad build up going on inside. I removed it. Seems like some sand/drywall powder buildup from some previous work around the house (from washing hand, etc). Good thing I was able to get this cleared up while I am redoing the pipes.
http://imageshack.us/a/img525/8749/imag0044qa.jpg
Thanks everyone that commented and helped out.
gregzoll 10-21-2012 04:22 PM
What do you mean by wanting to fit in a Ikea cabinet? They are standard sizing, just like any other cabinet. Most people will just cut a rectangle from the back, so they do not have to do any plumbing changes.
Alan 10-21-2012 11:49 PM
50 bucks says it has drawers. :wink:
