Question On Pressure Test - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-07-2013, 09:04 AM   #16
JOATMON
ddawg16's Avatar
Rewards Points: 1,836
I just did my leak test on Tuesday....but I used water.....and mine is 2-story...
I'm willing to bet that you have a vent somewhere you forgot to plug....
You mentioned that you "unplugged the toilet"...does this mean that you removed the plug for the toilet? Or is the toilet in place?
Like eplumber said....use water....you will find the leak.
ddawg16 is online now   Reply With Quote
Old 02-07-2013, 09:20 AM   #17
Roofmaster
Rewards Points: 2,210
Back to basics.
Did you purple prime all your connections a little deeper than the bells, use a large can of cement and dauber, glue bell, then spigot end, then insert your pipe fully, and rotate a 1/4 turn, Hold fitting in for a while, then trace around with glue?
Its amazing to me the force that the pipe applies to try and back out from the heat developed by the reaction of the glue. A lot of people don't get the pipe all the way in, and don't hold it in long enough. They walk away, and the pipe backs out.
Just some thoughts.
Old 02-07-2013, 04:30 PM   #18
yes i did not realize about the pipe working its way out or that i was supposed to prime a little past the connection, thats what makes me a rookie!
A man who's Bible is worn out is a man who is not.
garrettstump is offline   Reply With Quote
Old 02-07-2013, 04:52 PM   #19
if the video is small on youtube then change quality to atleast hd720 and it should get bigger.....
Old 02-08-2013, 08:25 PM   #20
I corrected the problem I used the shop vac to put a vacuum on all the lines and I went around with heavy duty plumbing glue and reglued all the fittings until glue filled all voids, I did the pressure test today and everything is perfectly fine, held 5 lbs for 30 minutes
Old 02-08-2013, 08:26 PM   #21
Call me a redneck but it worked
Old 02-11-2013, 02:15 PM   #22
Just to let everybody know I had the inspector come over today and everything is approved and my idea work
The Following 3 Users Say Thank You to garrettstump For This Useful Post:
bbo (02-11-2013), JDC (02-11-2013), TheEplumber (02-11-2013)
ABS drain pipe leaks under pressure test abracaboom Plumbing 12 01-24-2012 07:27 PM
Intermittent Low Water Pressure Fox Plumbing 4 03-02-2010 06:04 AM
Carrier pressure switch test spider18 HVAC 2 11-03-2009 04:51 AM
Water Pressure Question jamiedolan Plumbing 6 08-16-2009 12:43 PM
Pressure Balanced faucet question scp Plumbing 2 01-07-2007 05:15 PM
