Question, Installing A Tub Filler - Plumbing - DIY Home Improvement | DIYChatroom
Old 04-09-2014, 06:56 PM   #1
Rewards Points: 117
Question, installing a tub filler
I'm trying to install a tub filler for a freestanding tub as shown in picture. The picture is also shows a figure taken from the installation manual showing the piping setup required.
My question is, the connector shown in image as "5", is that necessary at all? I couldn't figure out why that is even there, as the water supply could be connected directly to the T-adapter (shown as 4) without "5". Intuitively, I'm thinking the less parts, the less chances of leaks, hence if "5" is useless, I'd like to omitted.
The manual made no mention of why "5" is needed, or whether it is optional or not.
Could I omit "5"? Or am I missing something obvious to why "5" is needed?
Thanks!
jsunsun is offline   Reply With Quote
Old 04-09-2014, 07:22 PM   #2
DIY staff
Rewards Points: 7,174
5 looks like a reducing bushing of some sort---what suze is the manifold threading?
What type of pipe are you using?
Is the inside of the manifold sized for sweating copper directly to the manifold?
Old 04-09-2014, 07:23 PM   #3
Maybe as you have suggested, you don't need them if your pipes line up correctly without them.
Please wait for the plumbers to respond. Thanks.
jmon is online now   Reply With Quote
Old 04-09-2014, 08:50 PM   #4
Rewards Points: 117
Yeah the manifold sized for sweating does fit on the T-adapter (4), exactly the same way "5" fits on the T-adapter. That's why I'm puzzled to why "5" is even needed. I'll be soldering 1/2" copper pipes to this assembly.
Old 04-10-2014, 03:41 AM   #5
DIY staff
I agree---eliminate #5---solder directly to #4---
Old 04-10-2014, 07:43 PM   #6
Rewards Points: 582
it looks like they just provided adapters for you ....see know reason why you cannot do it your way.... go for it ...let us know how you make out..
The Following User Says Thank You to ben's plumbing For This Useful Post:
oh'mike (04-10-2014)
general wiring question (installing exterior light) utilitylocator Electrical 7 01-24-2010 11:52 AM
Question on installing pergo stair nose amaruenterprise Carpentry 11 10-11-2009 05:21 PM
question on installing stucco siding? Rusty Bottoms Building & Construction 7 10-27-2006 02:26 PM
Question on installing floating hardwood floor loragail Flooring 7 10-23-2006 09:06 AM
Installing a ceiling fixture Cregan Electrical 3 02-08-2004 09:43 PM
